Results 1 to 8 of 8
    Wheels spacers ve hsv?
    Just wondering what size works on stock ve gts wheels and tires
    Id be getting hubcentric
    Just wondering if studs need to be cut and what size fits without tire rubbing??
    The rims on stock are tucked too far in particulary on the rear
    ... illegal for road use on any HSV (or Commodore)
    anywhere in Australia
    Smitty
    I dont care
    Newcastle, NSW
    I bought these years ago : -
    https://www.ebay.com.au/itm/2PCS-Whe...frcectupt=true
    I had to cut the end of the original wheel stud off for it all to fit - not ideal..
    I then went to these: -
    https://www.ebay.com.au/itm/HOLDEN-C...frcectupt=true
    they come with lengthened nuts & work a treat....
    2018 FORD FOCUS RS LE
    Thanks id rather get hubcentric
    Is vl and ve same size and bolt pattern?
    And studs still long enough?
    Quote Originally Posted by craze View Post
    Same bolt pattern, different hub and stud size.
    Newcastle, NSW
    Sorry, I didn't go through my purchased items on eBay - copied VL spacers by mistake, but you get the idea..
    I bought them for my VE so the front wheels would clear the coil overs with negative 3.5' camber.
    The ones I bought are 12 or 12.5 mm thick, and come with longer wheel nuts - longer threaded shank so to speak.
    If I could figure out how to post photo's again I could show you.
    PM me your ph & I can take a photo & send to you if you like..
    went through my eBay purchases & found them: -
    https://www.ebay.com.au/p/4003021543?iid=272760782710
    & yes, they are "hub centric"
    Don't know if still available but from memory when I messaged ole mate he could still make them to order....
