Results 1 to 6 of 6
    LS3/LSA Blower Spacer Plates Update
    🚙 PRODUCT UPDATE 🚙
    Time to step it up another level, LS3,LSA,LS9,L98,L77 rectangle port blower spacer plates are now available with 1 piece custom O-rings on each intake port
    ✔️ Dyno proven HP gains
    ✔️ Custom O-rings on each intake port
    ✔️ Isolate the supercharger from the engine
    ✔️ Prevent heat soaking the blower
    ✔️ Lowers intake temps
    ✔️ Gain back ignition timing
    ✔️ Stealth Installation
    ✔️ No silicone required
    Buy Online Now 🛒 http://fiinterchillers.com/shop/prod...lates-ls3-lsa/
    ...and the advantages of these over the original spacer plates Kirk ??
    GTSR Maloo
    Quote Originally Posted by markost View Post
    As you know the original plates have been in use for years, there is physically nothing wrong with the old plates, it simply requires you to use silicone on the original ones to keep the plates in place. The plates themselves are pliable and seal to the heads.
    The new plates are exactly the same but now remove the need to use any silicone.
    Anything to get rid of Silicone is a good thing.
    GTSR Maloo
    im going to be cutting in a channel for my LS2 plates to fit in some orings, ive done some port matching with them to suit my new cnc'd heads the material very easy to work with which is good
    Nice keep me updated
