Page 15 of 15 First << ... 5131415
Results 141 to 148 of 148
  1. #141
    cheers, all this now makes the 1/4 mile so much more interesting and challenging with what I have now I can see a sub 11.3.
    At 25psi on the first two runs with MT,'s on, I backed off, the car felt like it had an extra 150kws, I went from the grange to gts, the MT's felt like double that!
    Odd that when I launched sideways and powered OFF, that was my only 199 trap speed, the 11.50 was 189. So many options now with rpm psi power. I also turned the car off, and a few times did not have enough time to idle the car long enough to get the AIT2 down, it does drop fast thought with the: 16 hoses, 12L tank and chiller with the fans on full at idle, air temp was in the 30's AIT1 was around 60 in the line up.
  2. #142
    A quiet night at the plex, track cars testing and a masive crowd for the burnouts. I did a few 11.5s a 189. A 199 slower time. Went from 25 to 18 psi sports to track mode no burn out. I'd like to try 30 with a 2 second burnout. What I do have is a serious vibration time for the koya's to come off that will confirm the fault it was bad almost a no go
    Got about 12 runs in 4 from 1800 to 1830!
  3. #143
    Seems pretty inconsistent unless I'm reading things wrong? Varying trap speed from 189-199km/h? Which is 118-124MPH? That's a big gap!
    18psi is very low though, that will pull a fair bit of speed out of it IMO. Should be able to run them around 22-23psi most of the time. Keep the burn out going until they give you the hurry up just to see how they hook up with a lot of heat in them.
    Are you using the ET's just at the track or are you driving around on them?
  4. #144
    What was the temp over there?
    Hopefully my car arrives before I start work in late January so I can there before work gets busy.
  5. #145
    Cheers I drove to the track my plan is to leave them on for a few weeks doing the wed night then change. I may change to doing tyre changes at the track the compressor takes 10 minutes from 18 to 35 to drive home. Yes I can't understand the speed versus times I think I need more heat and more psi in the tyres. I did a 0.000 reaction a few 1.7' 's I may get the tune adjusted once the SF05 and MT are balanced they did move on the rims. The chiller worked a treat.
    Track air temp 11th Dec got down to 33 deg, last night down to 24, it was a good night almost too fast a turn around.
    Getting to the motor plex at 1730 for a 1800 start is the go.
    I must add burnout spectators GROW UP driving home it's a bad look get on the track or stay home. That's why we have the motor plex. Police need to setup a camera . P does not stand for drive at any speed on the public roads.
  6. #146
    Supercheap WA has 30 percent off everthing.
    Big Green sucker, gearbox oil ( astra), torque wrench . Had to go past the car lift trolley Jacks though. Merry Christmas and Happy boxing day buying cheers. Andrew.
  7. #147
    Has anyone noticed its not so easy to ballance MT's?
    From 100 to 200 vibration is not good i guess the tyre moving on the rim does this i may stay at 22- 25 psi and try more heat. Cheers.
  8. #148
    Quote Originally Posted by Andrew_02 View Post
    I know of a workshop here in Sydney they is drilling the Koya rims and putting screws through the tire to stop it from turning on the rim, they are doing it to 3-5 different VF GTS's
    Prior to this they marked the rim/tire with a texter and saw it rotate on the rim quite a bit.
