    Tyre pressure monitor fault.
    Hi all.
    I tried a search for this, but must have done it wrong because i didnt find much.
    After kerbing my left front wheel yesterday, i changed the wheel for the brand new spare in the boot.
    While out on a short drive today, a tyre pressure system fault came up on the display.
    Is there any connection between the changed tyre and the fault? and if so, what do i do about it.
    Theres no sensor in the spare tyre. I think it has to be changed over from damaged tyre.
    Sent from my SM-N910G using Tapatalk
    Mar 2013
    Sunbury Vic.
    Even if the spare had a sensor fitted, the system would require a 're-learn' to avoid a TPMS fault.
    Quote Originally Posted by lmoengnr View Post
    .................. the system would require a 're-learn' to avoid a TPMS fault.
    and how is that done on VF GenF models???
    lots of noise on Google about this.. but no actual step by step
    I can see all the tyre pressures using the stalk vehicle menu system.. nice
    but a reset???
    lots of stuff like press one knob on the key.. then another then try and start the car
    Keh?
    Smitty
    Member PIARC VICV8s Old Fart Racing
    GEN-F R8 340 Clubsport Tourer VK race car Kwaka ZX12R
    Mar 2013
    Sunbury Vic.
    Quote Originally Posted by Smitty View Post
    but a reset???
    Keh?
    Press and hold the button on the end of the stalk to get into the re-learn process.
    You'll need a TPMS tool to 'activate' the re-learn process, Gen F doesn't use the deflation method like the E series.
