Results 1 to 3 of 3
    Thermal Reduction Blanket
    If the blanket is going to reflect some of the upward heat and push it back down into the engine, wouldn't that cause higher temps inside the motor? (eg. Pistons, oil, etc.)
    I could be wildly wrong but would be interesting to log the temps before and after.
    If that blanket is going to reflect some of the upward head and push it back down into the engine, wouldn't that cause higher temps inside the motor? (eg. Pistons, oil, etc.)
    On the test car we tried this on, we logged oil temp and coolant temp figuring this might rise up, it however remained the same.
    Likely that the heat is dissipating in the same area and just going to the ambient air under the air gap of the charger, or it's losing the temp from other areas of the engine and cooling system.
