Results 1 to 5 of 5
    LSA Oil System Guide
    Click here to read about the LSA Oil System http://fiinterchillers.com/lsa-oil-system-guide/
    Any questions you may have please don't hesitate to ask.
    Great read, thanks for that kirk.
    Love learning about the potential areas to improve these motors for longevity, I for one plan on keeping this car for a long time and want to look after it correctly from the get go.
    Cheers.
    55psi in the top end seems awfully low for a high performance motor.
    If we run a slightly thicker oil, say 10W50, would this increase the oil pressure?
    Yes if you have deleted the relief valve and shimmed the pump, I run a 10w40
    If you haven't done the relief valve and shimmed the pump then it will still bleed off at 55psi
