Results 1 to 8 of 8
    Dec 2015
    Question on springs
    Hi guys. Today i got my Pedders sports ryder springs fitted. Surprised at how comfortable the ride is. Not factory comfortable but pretty damn good.
    The ride height of the rears is 100% perfect. Looks visible lower but not to low. The fronts on the other hand visually look like they have lowered by maybe 5mm but look to be sitting higher than the rears. Will the fronts settle in a little lower once they bed in?
    Also how long should i leave it before i get a wheel alignment done?
    Both ends will settle a little. Did you keep the MRC? It may change a little depending on modes as well
    Dec 2015
    Yep i brought the MRC compliant springs. Both modes of MRC are reasonably firm now but thats how i like it.
    Did you or the installer measure before and after HTG???
    Dec 2015
    Yes. Thats why i'm a little puzzled about the front ride hieght. However i'm putting the minimal height drop down to the new strutt bearings. I figure once they have worn in it will drop to the expected height.
    Quote Originally Posted by NU13 View Post
    So what are the HTG measurements now??
    It will settle
    Align immediately
    Dec 2015
    Well ride height looks ***y as front and rear now with the fronts settling in nicely. Off for a wheel alignment tomorrow. I'll update on the actually ride height measurements on the weekend accompanied with a photo or two.
