Results 1 to 6 of 6
    Smile transmission cooler
    looking at putting a trans oil cooler any recommendations
    The biggest one you can fit
    Something like this would be ok
    http://torquelinegarage.com.au/ultra...10-x-15-5-an6/
    I had a Walkinshaw Performance trans cooler fitted to my old VE SSV from new as I had a big trailer boat at the time. I'm not sure what type it was but it seemed to do the job. The only reason I went with WP was because I felt with a brand new car I needed to be careful about the warranty side of things, so I had the dealer supply and fit it
    Would you fit a thermostat to control the fan so the gearbox is at operational temp before the fan will switch on
    Quote Originally Posted by MYVESSV8 View Post
    Yes.
    That one I linked doesn't state it but the smaller cooler below includes a 180F thermostat so it may be worth checking if there's one included already
    http://torquelinegarage.com.au/dual-...6-with-10-fan/
    next kit up for $250 has the thermo
    yep that's the one
