Results 1 to 6 of 6
    vz gto ls2 linking second hand ecm ?
    hi , have purchased a second hand e40ecm that I will be replacing over original and am asking what is the correct
    way to change.
    have all the security codes from my vehicle but this ecm I have purchased does not have its vin available or any other security codes . what would be my option to install thanks.
    getting desperate , any help much appreciated .
    Feb 2011
    Have you tried HSV directly ? Surely they can get into it to find the original codes.
    GTSR Maloo Interchiller
    Usually if your not a dealer they will not communicate with you for very long .
    Aug 2006
    I think you might be out of luck and need a ecm with a known VIN.
    Zorst video: https://youtu.be/R0oKu5PMQG4
    #21 2001 VX R8 series II (HSV Racing Green)
    #16 2006 HSV Dealer Team ClubSport (Phanton Black)
    #771 2010 E2 GTS (wildfire)
    Is it possible to plug the ecm in, and then hook up a tech2 to try and read the data on the ecm?
    Or won't it communicate at all like that?
