Results 1 to 10 of 22
    Dec 2015
    Odd problem with 1 key
    So one of my keys is giving me problems. When i use the spare key i am getting intermittent messages about the engine being immobilized and to consult the owners manual. So i thought, ok 10 year old battery, i'll change both keys battery. put new Energized batteries in both fobs along with dieelectric grease for good contact.
    My main key is still operating 100% but the spare is still giving me that message about the engine being immobilized please consult owners manual.
    Anyone struck this problem before?
    Anything in the manual about it?
    Did you buy new? http://forums.whirlpool.net.au/archive/2247825
    Also check this: http://www.hsvforum.com.au/showthrea...ilised-on-dash
    #771 2010 E2 GTS (wildfire)
    Quote Originally Posted by NU13 View Post
    If you live in melb i have a great guy who can help you out. All he does is car keys and will come to you plus pricing is good.
    VF GTS 2013 - BUILD #238
    VF Sen 2016
    VF SS-V Redline 2017
    Quote Originally Posted by GTS2017 View Post
    What will he do though? A new key?
    Dec 2015
    No nothing in the manual about it Audi. I'll have a read through those threads, failing figuring it out via the net i'll have to go into the steelership.
    GTS2017 i'm in the south island of New Zealand.
    I had the same problem and had a new key cut, the dealer will charge a small fortrune.
    Dec 2015
    So in your case was it the actual key shaft that goes into the barrel?
    It's probably not programmed correctly. They can re-use the same blade but you'll likely need a new fob and programming costs.
    It would only be an issue with the blade if it didn't turn in the barrel or door lock. Since it's saying it's an immobilizer issue, I would say it's the fob.
    New Fob as mentioned by WL
    Dec 2015
    It's an intermittent problem. Works "most" of the time.
