    Jun 2017
    Vf gts rear bar question (pic added)
    Just want to know if this section of the rear bar (on both sides) is ment to be clipped in under the boot or ment to be loose / flimsy.
    Sent from my SM-G935F using Tapatalk
    I donít believe mine is loose, but will double check when I get home in a couple of days
    Nov 2011
    North West NSW
    The rear bar on the passenger side of my 2013 genf required the clips replaced. I was told it was a known fault on early genf models.
    Previous 2011 MY 12 VE R8 Maloo -Perfect Blue
    Current 2013 VF GTS W507 - Herron White
    Jun 2017
    Hmm interesting... mine does it and so does my mates but for some reason it doesnt seem right to me
    Nov 2011
    North West NSW
    On mine it started to droop below the tail light then it progressed outward towards the blinker. Finally over a short period of time the side panel would drop about 10mm. I could lift it and push it back into position and it would stay in place for a while. Eventually it would not go back into position a5 all. The local Holden dealer fixed it by replacing the clips under the tail light.
