Results 1 to 10 of 10
    E2 excessive backlash?
    Does anyone know whether or not this backlash from the drive shaft to the diff is excessive? This handbrake is on and the cars in gear.
    80,000km on the car and original diff oil in.
    https://youtu.be/y1ZEbI8TEHM
    #771 2010 E2 GTS (wildfire)
    That's still mint Audi. You should see how much on the true trac
    yea that looks pretty standard for stock mine is about the same
    Awesome guys! That's what I wanted to hear, was just unsure. Thanks
    Jul 2017
    Mine is about the same amount on my Gen f GTS
    Cool, looks pretty easy to change the fluid too so might slap some new stuff next weekend.
    Hi guys slightly off topic had backlash issue after True Trac install from Harrop changed diff oil to Mainlube no more backlash
    Jan 2011
    Quote Originally Posted by chippy69 View Post
    Oil change will not affect backlash
    Jul 2017
    As Eors said, oil can't remove backlash
    Sep 2017
    I think chippy's referring to the noise rather than the actual measurable backlash, my VE had a very audible clunk when getting on and off the power after a Harrop Truetrac install, rechecked everything including calling Harrop to discuss and the consensus was that it was normal, changed diff oil from 75/90 to 85/140ish and there was a 100% improvement, the backlash was the same but the noise and clunk were nowhere near as noticeable.
