Results 1 to 6 of 6
    Dec 2013
    Console shifter surround won't fit
    Hi guys, only just had a few small panel work touch up jobs done and also replaced my console surround that had a broken mounting clip. Since it was silver they had to paint the new part to match. The problem is when I got the car back the insert is just sitting on the rear edge of the console recess, the clips barely located and just held in place by the screws up front. No matter how much I try to force it I can't get it to move enough to let it sit down into the recess and clip properly too.
    VX console shifter insert problems (3) by Aus78Formula, on Flickr
    VX console shifter insert problems (2) by Aus78Formula, on Flickr
    VX console shifter insert problems (1) by Aus78Formula, on Flickr
    Looking at this VX console light instruction post it shows a few areas that may be able to be adjusted. I've already tried just the two nuts inside the console bin with sliding room, the console body needs to come back about 1-2mm to let the insert drop down, but it didn't budge at all. There's also 2 screws up front under the insert once removed that face down, but I cant see many that really offer adjustment, only single area fastening. Many would need a spacer washer or similar which is obviously not right. Any ideas?
    https://forums.justcommodores.com.au...e-light.75600/
    Ben
    1978 Firebird Formula 6.6L W50
    2002 HSV Clubsport R8 255
    Dec 2013
    same response from the panel shop that left console in this condition calling it complete
    Ben
    can I ask what colour you had it painted
    Dec 2013
    I believe it was a custom mix, they gave back my damaged original console surround but with about 5 different silver stripes sprayed on it where trying to match. Done a good job, pity they can't assemble consoles.
    Ben
    Jun 2017
    Did you get it to sit properly?
    Dec 2013
    Not yet, I've only had time to undo a few things and probe at it, without any obvious cause. Next is to pull entire dash facia and hope it's somehow now seated properly by a few mm and sitting out, because there's no other obvious thing showing.
    Ben
