Results 1 to 10 of 12
    LSA Lid Spacer Special!!!
    Bolt on 20HP in 20min
    LSA lid spacer before/after dyno test
    Free shipping* this week only!
    *Free shipping is for Australian residents only
    100% independent from us, Steve at Vision Automotive in Sunshine North VIC, also picked up 20rwhp with our LSA Lid Spacer.
    Plates have thermal reduction properties, so lower intake temps.
    Air flow into the rear cylinders has now been improved.
    In addition to that since the intercooler brick is also spaced further away from the rotor V the air has more time to spread out wider and use more of the intercoolers brick surface for further cooling.
    You can again see in this picture how restricted the rear cylinders are.
    End of the day the spacer does 3 major things colder IAT's and more air flow from the blower discharge going through the entire surface of the brick and more air to all cylinders.
    Install video here:
    Aug 2017
    Sydney NSW
    One of the first bolt on mods that should be done in my opinion. A good time to put one in before Summer comes along. A distinct IAT2 reduction and less heatsoak on hot starts. The power added is a bonus.
    2016 VF II SSV-R Wagon with LSA Blower
    Quote Originally Posted by Scotty82 View Post
    Cheers Scotty82,
    Scotts review of the spacer is here he did all mods in stages to log and see progress and results from each mod
    http://www.hsvforum.com.au/showthrea...iller-Feedback
    Plenty of people have taken up this special, I am going to continue it until Tuesday the 5th for anyone that may have not seen the post, had the time to get in touch etc and then it will be back to normal.
    Bump guys offer ends tomorrow night.
    Sep 2017
    Putting a LSA Blower on my VE Maloo, is there enough clearance under the bonnet to add this spacer?
    Sent from my iPhone using HSV Forum
    Quote Originally Posted by IR8 View Post
    Spacer is 10mm thick you should be fine
    Sep 2017
    isnt there 2 spacers? 1 set on the heads and 1 in the Supercharger?
    Yes there are 2 different products.
    1. LSA lid spacer (info above how they work)
    2. LSA/LS3 style Blower spacer plates (stops engine heat absorbing into the blower)
    You can see in the last photo on the first post both the LSA lid spacer and blower spacers on the bench.
