Page 5 of 7 First << ... 34567 Last >>
Results 41 to 50 of 69
Thread: W1
  1. #41
    Oct 2015
    so what are thoughts re hub vs rollers? would you say hub dynos read higher?
  2. #42
    Aug 2006
    For sure
    Zorst video: https://youtu.be/R0oKu5PMQG4
    #21 2001 VX R8 series II (HSV Racing Green)
    #16 2006 HSV Dealer Team ClubSport (Phanton Black)
    #771 2010 E2 GTS (wildfire)
  3. #43
    Liverpool Sydney
    Not many people have experienced a proper dyno cell.
    No idea if harrop has a proper cell or not.
    One I've been in is incredible, once that room is sealed the vacuum from the rear extractor is insane air speed blows your t-shirt even without the front dyno fan turned on.
    It is basically the same as road conditions in terms of air flow around, beside, under and over the car.
    True that.
    Ive had the pleasure of taking a few engines to Kim Baker in Molong NSW and his Engine Dyno set up is mazing
    LS2 V3 Vortech Supercharged
    607rwhp
  4. #44
    Jan 2016
    Very interesting guys
    Sent from my SM-G930F using Tapatalk
  5. #45
    Sep 2017
    Perth
    That is one very nice motor vehicle. If I had some spare $$$ I'd have bought one. Make sure you enjoy it and don't just park it up.
  6. #46
    Question without notice - Anyone who owns a W1 - do you have any problems getting off the line in a drag situation, starting from 1st then to 2nd and 3rd..
    Reason - I was with someone today who owns a W1 and he mention this issue to me after we had a run together, I myself run a auto and my third pulled alot harder than his.
  7. #47
    Quote Originally Posted by GTS2017 View Post
    Just another question does the W1 come with Launch Control (Manual Transmission only) and if yes, has anyone tried it that owns a W1.
  8. #48
    Just a note for W1 owners - be aware that there are potential coolant leaks on W1's - HSV are aware of them ( and have been for weeks) - and formulating a fix apparently - but first acted dumb on enquiry. I think its a bit wrong of them to not notify owners to change clamps in the interim like I have done - only to discover when doing so another leak from the supercharging cooling system in the front bar ! Keep an eye out - I noticed the leak moving the car ! Bit disappointed
  9. #49
    Jan 2016
    thank you groupa88 some one told me to get rid of a clamp in one of my engine shots i posted on this thread i will investigate further thanks again
  10. #50
    Jan 2016
    what was mentioned was the thermostat hose clamp i checked prievous post will look into it when i get home in 2 weeks
