Results 1 to 10 of 22
    Jan 2017
    E series Fog & Driving light bulb type?
    VE HSV fog light and the driving lights (come on with high beam) above the fog light.
    Can someone confirm if they are both H3? and what wattage they are.
    Nothing in the manual, cheers.
    Sunbury Vic.
    E2/3 driving light lamps are H3.
    Jan 2017
    Thanks, and fogs are the same right?
    Sunbury Vic.
    Not sure, only the E1 came with foglights.
    I think you might need to post a picture of the front of your car and tell us which lights you're talking about.
    E2/3s do not have fog lights, only driving lights, they come on with the high beam - not switched separately.
    Above them are the DRLs which are LED and then in the main headlights are you parkers, and low and high beams.
    Jan 2017
    It is E1 2007
    Jan 2017
    Quote Originally Posted by GTS Happy View Post
    It is E1 2007
    Sent from my iPad using Tapatalk
    Sunbury Vic.
    You might have to remove an inner front guard and eye ball the lamps.
    They're H3 mate. I think the originals are either 15w or 35w. I used 50w or 100w, can't remember, but they're fine.
    To change them, the easiest way I found was to remove the plastic inner guard, un-clip the wiring harness, and then remove the whole unit by taking out the 4 Philips head screws that hold the fog light assembly to the front bar.
    It's easier than trying to get the globes in while the assembly is still bolted to the bar. I'd change all four while you've got them out. Saves you having to do the whole process again.
    Quote Originally Posted by Y2Clubby View Post
    They're H3 mate. I think the originals are either 15w or 35w. I used 50w or 100w, can't remember, but they're fine..
    I dont think its a good idea to use 100w. I would go with 50w`
