Results 1 to 5 of 5
    Stability control keeps turning off
    Hey guys,
    I have a VE series 1 HSV Senator. It has an intermittent problem where the car uses about 50% more fuel than it should, it shakes on idle and causes the stability control to turn off when this happens. When idle it uses over 3L per hour compared to 2L per hour when running normal.
    Anyone have any idea why this would be happening?
    Sent from my iPad using Tapatalk
    id start with O2 sensors
    get the codes checked
    Thanks for that. I get o2 sensor too lean code sometimes. Previous owner upgraded the exhaust. I was told the sensor got replaced when I bought it. I'll change all the sensors and see how I go.
    u may just need to get the rear 02's ignored if an exhaust has been fitted with no tune otherwise u can keep fitting new 02's and code will always come back, especially if they have already been replaced
