Results 11 to 12 of 12
Thread: Tuning
    [QUOTE=csgts;184087]What happens to the sport shift mode when you get a tune? Is it possible to have 2 stored custom tunes? Maybe a "street" tune and a "race" tune (1 as 'normal shift' and the other as 'sport shift')?[IMG]https://uploads.tapatalk
    What should happen is "D" is tuned by the Technician, "Sport" is derived by combined Software calculations of the ECU and TCM
    The ECU and TCM use a "torque calculation" so that the shifts are soft when cruising and increase in firmness as the throttle is applied.
    So there is no need to have two distinctive trans tunes done.
    Any Workshop using 6l80etuning.com advise will safely make the adjustments you require.
    Might be cheaper than you think.
    If you are in WA try Cameron.
    http://turnerautotech.net.au/
    Always better to get a Workshop to make the adjustments to the tune.
    What is your plan if the mail order tune fries your transmission?
    Ed.
    Aug 2016
    [QUOTE=ed.harris;184279]
    Quote Originally Posted by csgts View Post
    Ed.
    Thanks for the info! I will be getting dyno tuned, not sure what these other blokes are talking about mail order tunes for??
    Sent from my SM-G950F using Tapatalk
