Results 1 to 10 of 10
Thread: vy clubsport
    May 2017
    vy clubsport
    Hi my clubby isaking a ticking sound every now and then is this just a sticky lifter or ?.if so how can I fix it.the machanic said Iit could be the o-ring in the lifter is there even a lifter in the lifters ?
    Could be any number of things but high possibility it's a lifter. If you're getting low oil pressure as per your other threads, the engine may not be in very good shape at all
    May 2017
    Do the lifters have orings in them
    No.
    Are you sure he didn't mean the o ring on the oil pump/pickup? It's common for that to wear, which then causes pressure issues and if the pressure is so low the lifters aren't getting adequate flow then they'll tick
    May 2017
    Iv done a manual oil pressure test with the gauge and it says it as heaps of pressure so
    Define "heaps"?
    You want around 30psi at hot idle and 10psi for every 1000rpm after that.
    If the light was coming on like you said previously, it's very low. It may not be occurring all the time, maybe only at start up, at higher rpm or some other condition
    May 2017
    Wat is that in bar
    2 bar at idle and 0.7 every 1000rpm there after.
    Is it an actual mechanical gauge or the one on the dash?
    May 2017
    On the dash
    That's an electrical gauge, not mechanical...and mine was never accurate
