Results 1 to 5 of 5
    LSA Blower Project
    I posted these pictures a while back about modding the LSA snout/byp*** valve to allow more air flow into the charger. I dont know why anyone hasn't tried it yet...maybe too expensive or too difficult.
    Well anyway a friend of mine in the US has a LPE snout he's selling me, I'm going to mod the blower to suit the snout, and if needed mod the snout to suit the blower...see how this project pans out and if it's worth any extra HP.
    In this pic on the left is the LS9 snout which has the higher byp*** valve area, on the right is the LSA which has the red line on it, I intend on welding this up on the blower side and then grinding it down to match the LPE snout.
    This is where the welding will take place on the blower side
    Aug 2015
    Are the snouts interchangeable? They look similar in their bolt patterns.
    Quote Originally Posted by maloogts View Post
    Other than the byp*** valve area where one is higher and one is lower
    I'm planning on doing this in the next couple of weeks, haven't had much time to even look at it lately with my work load and racing.
    I'm hoping this will free the blower up and get more air into it, I certainly don't think it's going to hurt HP, at a minimum if I can find another 20hp I'll be happy, at the level I'm at now it's hard to find HP I'm going to have to work hard for it.
    With the mph at the track being pretty consistent and the dyno I use also very consistent I should be able to tell if it's working.
    This was a much bigger job than anticipated, my fabricator didn't like me much after doing this for me...LOL
    We had to make a new billet input shaft which was the most difficult part as the LPE one isn't as long as the LSA.
    Welding and grinding down to suit wasn't that bad but did take a while to build up and grind back down.
    Throttle body still sits in the same location, snout is closer to the throttle body which makes changing the belt a throttle body off situation, bit of a h***le but hey thats the price.
    Took these pics during install and cam swap.
