Results 1 to 10 of 19
    Jun 2015
    Perth WA
    Rear wheel to flywheel conversion.
    How do you figure out flywheel conversions. I have 649 rwhp and 825 nm at the tread. What would flywheel be? Roughly obviously.
    VF GTS, 22.5% overdrive pulley, 2" primary 4-1 extractors on to twin 3" exhaust, Cold Air, 160 deg thermostat, Cam, double valve springs, 65lbs injectors. 649 rwhp.
    I've always said rwhp is close to flywheel kW. If you run up a car in standard form, it's generally pretty close
    I am not sure I get that.
    Are you are saying he has 649fwkw?
    or
    870fwhp?
    Smitty
    It's going to vary dyno to dyno.
    With dyno numbers you always want to be on the same dyno strapped into both rollers for consistency.
    Use the dyno purely for tuning.
    If you drag race the car the track will tell you your engine HP with your MPH versus weight.
    There are plenty of cars that claim big HP numbers but can't back them up at the track and mph never lies.
    I'd rather use a low reading dyno that's consistent than some of the Disney dynos out there.
    Quote Originally Posted by Smitty View Post
    or
    870fwhp?
    Yup.
    Some will say the drivetrain loss isn't a constant percentage (34% when converting HP to kW) but if you take a 100kw 4 cylinder and it makes 100rwhp then compare it to a 400kw V8 that makes 400rwhp, they're generally pretty similar, give or take for dynos, freak engines, some engines being constantly under rated, etc etc
    Jun 2015
    Perth WA
    Cheers for the replies but was only looking for a rough estimation, all dynos vary. My driving on the strip might no pay homage to the car.
    Kind of want to know the torque figure
    Quote Originally Posted by Remdogg View Post
    Roughly speaking - 649rwhp = 791hp at the flywheel ( 791fwhp ).
    Jun 2015
    Another way to look at it is this,
    Modified rwhp figure minus 100% stock rwhp figure added to the manufactures claimed standard flywheel figure to find new flywheel HP.
    Jun 2015
    Perth WA
    So if I take it down the 1/4 what's your formula to work out jp from my 1/4 mile time.
    This has been the tried and true method used for years and years and comes in pretty close
    http://m.ebay.com.au/itm/MOROSO-POWE...-/131453967576
    There are plenty of online calculators you plug ET, MPH and weight in to and they'll tell you what hp is required to run that.
