Results 1 to 9 of 9
Thread: 1st HSV.
    Apr 2017
    1st HSV.
    Hi all.
    Well it's taken a while but I've finally got one.
    15th anniversary R8.
    Won't be doing much driving as I brought it unregistered and haven't got the room for it ATM.
    We get on when I can for some storage tips.
    Cheers.
    Sent from my A1601 using Tapatalk
    Qld
    Hi welcome to the forum
    If your asking for storage tips?
    In part with nowhere to store or lock it up, you may not own it for long!
    Apart from removing a few fuses for security, the fuel tank should be plastic so leave the tank almost
    empty as you need to drain the fuel, google info on fuel life. Start the car and get the engine up to running temp
    every couple of weeks. Remove the battery and look after that separately.
    Their are a couple of good threads in this forum and others on car storage depending on how good the car is and how long you are
    going to store it. long term you should save the tyres and suspension by placing the car on blocks. Depending on
    where your car will be stored plug the exhaust/any holes, including the intake, just don't forget to unblock/have a check list
    prior to restarting. What is a 15th anniversary R8 a VX? cheers andrew
    Apr 2017
    Storage will be long term 1-2 years. My folks have the room so I'll park it up there. I'll put it up on stands and start it every week, could even get the old man to kick it over more frequently if needed. Will driving it on stands help or to best to give a run around the block every month or so?
    Yes 15th anniversary is a vx.
    1st HSV.
    1-2 years i wouldnt worry to much
    Put a batt tender on it, wheh ready to use it check tire pressure and change oil and re fuel and take her for a spin
    Take a look how low km ferraris can be despite their age
    Liverpool Sydney
    Quote Originally Posted by j_a_y View Post
    Its not good to start and idle the car without actually driving in it. I wouldnt do it weekly, perhaps monthly.
    LS2 V3 Vortech Supercharged
    607rwhp
    Apr 2017
    Thanks for the input guys.
    All taken onboard.
    Apr 2017
    Did an oil change yesterday and took it for a 20 km drive. Planning on doing that every month, the driving that is.
    Also noticed that there seems to be some undercarriage missing. It's the bit inbetween the front bumper and the plastic piece that's next to the metal cover. Bit hard to explain, will post a pic next weekend.
    Wheels and suspension will be up for sale in the next week or two.
    Oh. Brought a new battery as I couldn't even unlock the door, tried jump starting with my 4x4 with no luck. I'm disconnecting it when not using it.
    Perhaps look in to a good trickle charger like a CTEK to keep the battery healthy when you're not using it
    Apr 2017
    No power where it parked up unless I run a extension lead from the garage.
    Happy enough doing the battery thing.
