Results 1 to 8 of 8
    Ve s1 gts - air con
    Has anyone else had the problem of the AC turning on by itself?
    It only started doing it today, but did it 4 times in the space of 1 hour.
    I believe its either a bad earth or a bug in the tune?
    Aug 2016
    I have also had this problem on my 07 VE Clubsport. If I remember correctly it was after I charged my battery in my car without disconnecting the leads. Only did it a few times probably within an hour like yours. All good now.
    Quote Originally Posted by sjako View Post
    Mine is still doing it.
    We fiddled with the setting for the Thermo fans ( through the tune ) to get them to come in a bit earlier ( 90 degress ).
    It seems to be tripping the fan on the dash / ac
    Aug 2016
    Now wonder you wanted to have the thermos come on earlier, it's the rwhp that's causing your problems. LOL. The acceleration rate from your car must be pulling the a/c switch in. Just joking of course that's big hp. Sorry cant help with the main problem.
    Cheers Steve
    Cheers Steve
    haha!! We'll sort it out ( eventually )
    if you know someone with a Tech 2, they may be able to check if there is any HVAC errors logged.
    mine has just developed an odd issue i need a Tech 2 to diagnose.
    Quote Originally Posted by mitchy View Post
    Just gonna keep ab eye on it - see if it cycles out. Its only starting doing it since we dropped the thermos to 90degrees.
    It could well be a HVAC error - I'll run it up and see what happens.
    Whats your issue?
    Mine has decided the passenger only gets hot air. Replaced the HVAC actuator (a couple of times), but it still presists.
    It came at the same time I upgraded to E3 IQ, but I'm told it's not related.
