Results 11 to 20 of 23
    Port Hedland
    What bob said. So. Is the fan not working the issue here? Or are you not getting hot/cold air?
    Country Family 2.2 working for the Big Australian. Dual-trade mechanic LV/SME.
    Favourite saying: Go Dad! Go! Ohh, Alright then.
    Rides:
    2015 Gen-F2 Clubsport R8 LSA 6 speed Auto Slipstream Blue: Mum's family car.
    K&N panel filter.
    2010 VE SS Redline Ute 6 speed Manual Red Hot: Dad's play rig.
    Unknown headers, 3" exhaust, 3" Hooker 21506 mufflers with 5" tips, OTR.
    2011 JG Cruze CDX 6 speed Auto Velvet Red: Dad's drive to work car.
    HSV badges lel.
    Quote Originally Posted by Bob33 View Post
    not the blower fan, have had ve's in with no gas and the fan still works for the heaters.
    Sent from my SM-G935F using Tapatalk
    Cool. I guess the Blower fan is the next step to test. Then to the HVAC module if the fan is ok. Not looking fwd to removing the glovebox lol
    Quote Originally Posted by LSA199 View Post
    No fan at all is blowing into the cabin. or I cannot feel anything through the vents hot or cold.
    Port Hedland
    Have you checked your fuses?
    Sounds suss, if your belt came off and destroyed some electrical stuff you might have bigger issues. You should call an auto sparky.
    Rides:
    K&N panel filter.
    HSV badges lel.
    Yeah things first started with the battery dying, and while it was sitting for the new battery, I randomly spotted the missing A/C fan belt, so after I replaced the battery I tried the Aircon and Heater and nothing worked. (Sadly, by this time I couldn't remember the last time the fans worked as I never use it often) So after learning about the harmonic balancer wobble and AC fan belts. I replaced both thinking it would also fix the Fan issue. It did not, so then thought maybe I had blown a fuse while replacing the battery. I only did a visual check by pulling out the fuse and looking for breaks. So I will try with a Mmeter next.
    1 Question does the blower fan have a separate fuse to the HVAC unit?
    Melbourne SE Suburbs
    Not sure about the E1, but on the VS, if you turned the fan to the highest setting the current came direct from a relay instead of via the fan speed controller. Might be worth a try.
    GEN-F2 GTS, VS Clubsport 185i
    Port Hedland
    Have you tried the reset trick for VE? Hold the demist button in for 10 seconds?
    Rides:
    K&N panel filter.
    HSV badges lel.
    Never heard of that?
    What does it reset?
    Port Hedland
    It will reset/relearn the vent procedure. Give it a try and let us know how it goes.
    Rides:
    K&N panel filter.
    HSV badges lel.
    I'll give it a shot if my problem persists - thanks for the tip
