Results 1 to 10 of 17
    Autowerks Before/After Forced Induction Interchiller dyno
    AutoWerks Automotive 100% independent of us completed a before/after dyno test gaining 41rwkw/55rwhp and lots more TORQUE!!!
    Fitted with our interchiller + comp solenoid and our 6.5L reservoir.
    Watch until the end of the video showing average HP and TQ gains.
    That will be my car on that dyno sooner then later hopefully
    Another video from Sonny and the team at autowerks.
    This is a VF SS fitted with a Harrop 2300 blower.
    Autowerks Automotive have fitted our thermal reduction blower spacer plates, along with our 6.5L reservoir and our race chiller + comp solenoid.
    The Harrop blower is downwards discharge so the use of our thermal reduction plates is a must to get the intercooler of the blower up off the very hot 100-110c engine to help stop heat absorption.
    This car is still running stock boost pressure of only 9psi, with a higher boost pressure more heat will be generated and gains from the colder temps will be even higher.
    The car has picked up 26.4rwkw (35.4rwhp) as can be seen this gain is throughout the power curve.
    After a 20min drive down to get some fuel after a wash last weekend. Pre chiller it would have been high 30's low 40's.
    Nice thats cool how your EDI is showing it since IAT1 has been relocated.
    AutoWerks Automotive smashing out another interchiller install.
    BEFORE: 409rwkw (548.4rwhp)
    AFTER: 424rwkw (568.5rwhp)
    AFTER + TUNE: 442.8rwkw (593.8rwhp)
    A gain of 33.8rwkw (45.4rwhp)
    Average kw/hp gain of 34.8rwkw (46.6rwhp)
    Average TQ gain of 108.7NM
    Im away from home for 2 weeks with work but am looking forward to this mod when im back.
    Just a question regarding the tune with the interchiller, if you have it tuned for when the chiller is working what happens if you don't run the A/C does the tune just retard timing to make it safer as im guessing that you can run more ignition advance when its running ??
    Your entire IAT2 table is tuned and simulated on the dyno from 0c to 100c so no matter what temp you are at you are making whatever HP at that temperature is physically possible.
