Page 2 of 2 First << 12
Results 11 to 14 of 14
    Darwin
    I'll x 2 that. The best mod you can do without doing a mod....
    Bi - Model open all the time so the car actually sounds like an V8...
    And also sounds better than all the local little phuckers that have bought series II SS's.
    even when in performance mode the bi-modal system restricts the sound ?
    hmmm ill give it a try
    Quote Originally Posted by Kornyj View Post
    The factory setup shuts the valve once speed goes over 10km/hr, and only opens it when on heavier throttle and or/RPM
    Pull the fuse out (must be in sport mode when car is turned off), and then the valve won't close at all, regardless or throttle or RPM
    In VF2 SS-V the fuse panel is next to the battery in the boot and the one to pull out is 13500128 - not sure if this is the same for HSV variants, but I'd assume so
    Jan 2011
    In my GTS Maloo the relay was behind the passenger seat under the carpet flap
    Darwin
    Holly crapzilla !! it sounds heeeeeeeeeeeaps better!!
    Thanks for the tip...
Tags for this Thread
