VF2 audio
9 speaker bose just isnt doing it for me. its pretty darn good for stock though I must say, but argg i just want abit more clarity and quality bass.
I dont wont to spend a fortune, Cash on hand is for engine work ... nothing quality comes cheap though i know that.
Anyone have any suggestions?
probably looking at amp, sub, speakers i guess? Not really in the know with audio...
thanks in advance
if they have the little stock sub amp just crank it up is set to minimum, in my ve i have it at max and then use the bass control on head unit for fine tuning and it sounds good for factory i even used deadner all over rear deck and doors and that helps too
Hello,
So is there a level adjustment on the factory sub amp? If so where is the amp located?
Thanks guys,
on sedan in boot just in front of battery, its a pain to get to the adjustment and if u look the amp is clipped in if u can un clip it it will then come out and u can adjust easily
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
