Results 1 to 10 of 17
    Dec 2010
    23i Steel Blue Velour - impossible to source?
    Hi guys,
    Currently trying to track down some of this stuff to redo the headlining of my vp. I knew it would be hard to find. Most upholsterers laugh and say good luck when I tell them what I'm after.
    Problem is nobody wants to touch the sunvisors which are trimmed in the same velour and appears to be heat pressed on the seams, which means I may be stuck with different colours, which is not preferable.
    Anybody have some of the steel blue velour on the roll?
    Other alternative is to reuse the old lining. I cleaned all the old foam and ran it though the washing machine twice and it came up like brand new. Was thinking of glueing a foam layer down first and then the lining, using clips to hold it in place, working out from the centre. That's what one upholsterer advised. Anybody done this before?
    Cheers!
    Dec 2015
    Yeah I went down yr path about year ago. And got a few samples sent over but there all ended up being different shades. So I gave up.
    Dec 2010
    Same, got samples but all are nowhere close to the original. Might just have to go down to Clark Rubber for a thin sheet of foam and then try and reuse the original lining. All of the upholsterers said it's possible however it went from a fixed price to an hourly rate as its pretty fiddly hehe.
    If only the sunvisors can be re-done, then all the colour matching problems would be solved as I would be free to use the closest colour on everything.
    Sep 2013
    Byron Bay
    I'd be researching who makes the sun visors for Holden and seeing if they would be as kind to do a "one off" for you
    2002 VX SS II Quicksilver 6M
    Dream Car:- HSV VL SS GRP A
    Mar 2014
    Perth. WA
    My headlining in my vp started to sag over ten years ago. So I went to local Perth upholsterers with a sample from my old headliner. They had to source it from a Melbourne business , and said it was the last piece of material in stock.
    An OEM business needs permission from Holden to remanufacture obsolete car parts - Holden has the legal rights to the part. Also there needs to be enough part volume for them to take interest in such an exercise, there to busy producing modern parts for modern cars.
    I tried to get The company HELLA that produced the Vq Caprice fog lamp for Holden, to remanufacture the product and that was the response they gave me. By the year 2001 Holden only had a four right hand side fog lamps & no left ones at $110 each. Today you can still get A few NOS pairs from $700 to 1k for your Vp senator, Vq statesman 5000i, Sv90, Sv93 & fifth anniversaries
    Sent from my iPad using Tapatalk
    Dec 2010
    Hmm thanks for the advice guys. I'll try and get an upholsterer to reuse the original lining with some new foam. Not sure if I want to have a crack at it myself because if I stuff it up then I can probably throw the material in the bin!
    Sep 2013
    Byron Bay
    I'm also searching high and low for 23i velour. I wonder how many mtrs would be required for someone to reproduce??
    Dec 2010
    I gave up in the end. The original lining had stretched so lining it up was impossible. I ordered 3 m of a blue velour and will post a pic when done. It's not steel blue but one of the closest blues I have found. Side by side it looks way off but if I can find someone to do a set of visors in the same material then it will look good.
    Mar 2014
    Perth. WA
