Page 2 of 2 First << 12
Results 11 to 19 of 19
    Quote Originally Posted by surfwagon View Post
    Ditto for the Elite catch can, easy to fit and works a treat.
    Thank you for the upload.
    Thats a perfect fitment and looks neat.
    Surfwagon
    Thank you for upload
    nice and neat
    i have an Autotechnica catch can, works a treat and half the price
    [IMG][/IMG]
    May consider autoechnica aswell.
    Its definitely priced well.
    Melbourne SE Suburbs
    I had an HPF oil catch can on my VX GTS and it didn't make a scrap of difference to the oil consumption.
    GEN-F2 GTS, VS Clubsport 185i
    Bondi
    Quote Originally Posted by PSteelVFGTS View Post
    "An oil catch can won't change oil usage".
    Its designed to get the oil vapour out of your inlet air.
    Oil vapour in the inlet charge can cause lowering of octane rating resulting in pinging.
    I have an Elite, just make sure you order the correct bracket as well, as they are not included (well from my experience 2 yrs ago).
    Now: Audi RS3 (11.07 & 133MPH)
    This article should answer what set up you'll need for your level of modifications.
    LS1 has a PCV valve , LS2 and later dont have a valve as such, the U pipe from valley to intake acts as one by means of baffles under lifter plate.
    Basically for modified engines its saying to plug the port in intake manifold and run line to intake pipe before TB which is at a constant low vacuum , whereas the port in intake manifold is high vacuum at idle but under load basically zero vacuum
    Diagrams in article show opposite to what we have here, so clean air is drivers side, dirty air passenger side for us.
    https://www.shophemi.com/images/medi..._ccv_bible.pdf
    Dec 2011
    The link doesn't seem to work.
    I went off these instructions.
    http://www.eliteengineeringusa.com/t..._Catch_Can.pdf
    It definitely made a difference to my car, when I installed mine.
