What year HSV got the LS6 intake ? Vx/ vu up ?
 Originally Posted by VX15ANNIV
oil pump as well, when the LS1's got the LS6 intake manifold they also got the LS6 oil pump which was an improvement over the original LS1 oil pumps.
How do you know if it’s got a LS6 intake ?
And what heads can you put on it ?
What is the LS6 intake part number please?
LS1 - 12560688. & 12556333.
LS6 - 12573572, & 88894339
12561184 & 12561182
Only VT's had the LS1 manifold.
Get CNC heads from Higgins like I mentioned previously in this thread, best bang for buck on an LS1
get a LS2 manifold with 4 bolt throttle body much better then the ls6
[QUOTE=white_lie;190989]LS1 - 12560688. & 12556333.
12561184 & 12561182
Get CNC heads from Higgins like I mentioned previously in this thread, best bang for buck on an LS1[/Q
I been told not to spend money on motor to it’s time to refresh it or get new one
As I will not get any more hp out of it . Will out shortening it’s working life ?
The LS2 manifold is a piece of crap just google upgrading from LS6.
In the states they were plastic welding LS2 snouts onto LS6 manifolds to get the biggest intake with the best flowing factory manifold.
If you want a better flowing manifold than the LS6 get FAST102 manifold.
This was the last mod I did to my LS2 and the engine gained torque from bottom to top of rev range with a max gain of around 20N.M at around 4500rpm.
There was only around 3-5kw gain in horsepower but it was the torque that was the telling part.
Read post#3 https://ls1tech.com/forums/generatio...s-90-92-a.html
