Results 11 to 20 of 38
    Just dropped my car off at Autotech engineering at Granville
    It's getting the yella terra 21% balancer , injectors , K&N filter , it already has 3 inch
    Hurricane exhaust and 3.7 diff gears ...
    How did you go mate?
    Now: Audi RS3
    It only made 346 rwkw , there is more in it , I'm going back Tuesday
    To run it up again , they said it had bad fuel in it and it started pinging when they tried to
    Put timing into it , AFR was 11.7 to 11.8 then went to 12 in the top end with about 12 pound of boost
    They said any more than 10 degrees of timing and it rattled , I was hoping for
    400 to 420 rwkw but it wasn't to be ,it goes great but I still think it should be
    Getting better numbers ...
    What fuel?
    busy service station?
    Old or new tank of fuel?
    Power is way down for 12 pound of boost. Like you say, should make an easy 400-410. Hopefully some fresh fuel fixes it
    Well it was a seven eleven near where I work in moorebank so I have been told after the fact
    They are notorious for shitty fuel , anyways I had half a tank in the car while it
    Sat at home for 3 weeks while I was doing the supercharger and heat exchange set up , so I'm thinking the bad fuel theory
    Maybe the problem will find out Tuesday ..
    Has anyone heard of bad fuel causing a car to ping when chasing power or is there any questions I need to be asking the tuner wheather they have check this or that setting ????
    i have had a bad tank of fuel before a dyno touchup just gets knock and basicly kills your good dyno runs but as long as everything alse looks good then it should be back to normal with better fuel, is it defiantly pinging or just the sensors showing it or is timing just being pulled from a form of spark retard..?
    It's not pinging now , as he pulled timing out of it
    So the knocking went away , it goes pretty good and sounds happy as I said before I know of a few other LS3
    Engined cars that have had the LSA blower added and they got over 500 HP with just an exhaust upgrade ...
    I have 22% over drive lower pulley and injectors plus full exhaust and K&N filter .... I don't think I'm over expecting that it should have at least another 40 to 50 RWKW
    Not sure if it was pinging or the sensors were picking something up
    I can only go off of what they were telling me when I picked the car up , it's a bit frustrating when your car falls short
    Of a target power figure when other cars with similar mods
    Are making the exact target I'm after
