Page 2 of 5 First << 1234 ... Last >>
Results 11 to 20 of 41
    I'm lower pulley, headers, CAI tune, Interchiller do 11.5's with drag radials currently
    As for RWHP reckon I'm 525ish
    Over driven the blower by how much?
    Supporting mods? Injectors? Fuel pump?
    Race cats or stock?
    Full exhaust or just headers?
    Quote Originally Posted by Eors View Post
    The chiller will still make a difference on a single run...the colder the intake air the better the volumetric efficiency..denser air charge...more horsepower...wheels turn quicker...faster times
    I reckon spending the 2-3k on a set of diff gears would yield a greater improvement. Could probably even add a converter and still have change.
    Why is it that when you want to make an NA car as quick as possible, theres more focus on gearing and suspension, yet most people running ultra quick times in the F's still run stock gear? Anyone actually tried it at the strip yet? Old mate put 3.7's in his GTS Maloo and said it woke it up so surely not a bad thing?
    You'd need injectors and probably close to needing something done with the pump side of things but no idea what pump they run. The E85 VE pumps would handle 550rwhp.
    Race cats or stock?
    28%od
    Id850
    Boosta pump
    Headers hi flow cats (stock rest exhaust
    Chiller
    Harrop pod
    Jan 2011
    I am not disputing any other mods...just stating that it will make a difference
    28%od
    Id850
    Boosta pump
    Chiller
    Harrop pod
    Ok so your best is an 11.5 considered a mid 11 pass with the mods you have once you finally put some decent rubber on it
    As for the driveline personally I feel the GTS has all you need from factory, no need for converters or diff gears, hell I've seen a 1.5 60ft from mine. So I don't think it's lacking.
    Do you not think 1.4 or quicker is there for the taking though?
    ZL1's with better wider rubber are doing it with the exact same driveline as the GTS I see no reason I can't get a 1.4 next time I get out there.
    I've been doing 1.5's with traction issues, last time I had pretty bad wheel spin and still got a 1.54
    May 2013
    That is more important than a boost in power, getting all the power you have to the ground, it's the number one issue drag cars have dialing in the track.
    Quote Originally Posted by zRoYz View Post
    A car that runs low 11's though isn't going to have as many traction issues as a car like mine.
    NickGTS proved that when he put radials on he dropped 2 tenths of a second and hooked no problems at all running an 11.5 so in reality a low 11 eg lets say 11.3-11.0 would simply need a little more grunt off the line.
    How much does a ZL1 weigh?
    Which is easily solved with a set of diff gears.... If the manual diff is 3.7's, it would be a very easy swap
