Page 21 of 21 First << ... 11192021
Results 201 to 204 of 204
  1. #201
    Mar 2016
    So when I cam my car I know I will loose boost , because I have the 28% lower would I be able to go a upper pulley and get say 35% overdrive or is there not a upper pulley that will go with a 28% lower , meaning I will have to go a smaller bottom pulley and a top pulley to get over 30% depending on where my boost is after the cam is installed ???? I know my tuner will sort past this out but I do like to learn this stuff so I have a little bit of knowledge as to what I get done to my car
  2. #202
    Quote Originally Posted by Silverfox666 View Post
    You will need a smaller lower pulley to go with the smaller top put otherwise blower RPM is way to high
    Looking for colder IAT’s? we’ve achieved 11c IAT2 on a 41c day and -8c during winter.
  3. #203
    You have many sizes of options:
    8.25" (209.55mm)
    8.66" (219.96mm)
    9.17" (232.91mm)
    9.55" (242.57mm)
    9.73" (247.14mm)
    10" (254mm)
    That's assuming the 8.66" is exact and not rounded down from a conversion from 220mm.
    Boost in the cylinder will depend on valve events, how well the engine breathes, engine RPM etc. Just because you're changing the cam doesn't mean you'll automatically see less boost.
    Have a look at the Lingenfelter table, you can see what effect different upper and lower pulley combinations have on overdrive and maximum recommendations for blower speed.
  4. #204
    Mar 2016
    Ok cheers will do
