Results 1 to 8 of 8
    BAP Install Tips
    I installed my BAP over the weekend, I bought the kenne bell kit from Lingenfelter which included everything for the Camaro.
    got it here: http://www.lingenfelter.com/product/L460111410.html
    The instructions state to cut the FPCM wire and connect the 17v wire to this.
    I didn't like the idea of doing it this way in as it seemed a bit untidy and not well thought out.
    So here is what I did.
    I bought a fuse socket, you can find these on ebay, this plugs directly into the fuse that powers the FPCM and allows you to solder terminals onto the exposed pins.
    I tested the FPCM fuse for which side of the fuse was power and which side was sending that power to the control module.
    I then wired the power source from the power side of the fuse socket to the BAP and the 17v source to the other side.
    This resulted in a very neat install and nothing on the car was cut in order to complete the install.
    Should the BAP fail or blow a fuse i can simply put the original fuse back in the original fuse location and drive home avoiding going into boost.
    (Of course I am carrying spare fuses anyway in case this happens)
    But the install is highly easy and easily reversible, none of the connections are lose or will come out in any way.
    This was much better than the suggestion instructions of cut the FPCM wire that goes to the fuse and mess around with removing the fuse box in order to do it. This is also a much faster way of installing the BAP.
    The pressure switch is in the engine bay and activates at 5psi, this has bumped my fuel pressure up from 45psi to 65psi now with ID850 injectors so there is boat loads of room now, the pump runs on 12v until the car hits 5psi, at which point 17v is "available" when i say available it may not be used until the ECU demands more pressure.
    Think of this as more muscle behind the system, when it goes 17v the ECU may still be demanding 50psi of pressure it's not until the ECU demands 65psi is it then that the fuel system in 12v format isn't able to keep up fast enough to maintain 65psi so the extra muscle the 17v is used.
    This mod is way cheaper than a complete fuel system and the 17v is only being applied when the demand is required so the pump isn't being over supply voltage constantly....however many US guys do wire them up for constant 17v and I have not heard of anyone having any issues with them.
    so when the fuse blows the pump still works just dosnt get the power increase..? seems like the same situation i have with my twin pump setup sure the second pump will keep u going but jees if u dont know one pump is not working u can be in trouble ( lucky mine gave me a violent warning as i slowly entered boost rather lean ) would have been bad if i was under a full boot, would be good if u could have it trigger a DTC warning for loss of power to FPCM or something simular when the fuse blows then u have a pop up on the dash that lets u know just encase
    No it doesn't work like that the BAP is now supplying 12v to the FPCM if the fuse blows i have no fuel, i then have the choice to replace the BAP fuse and continue racing etc etc or replace the FPCM fuse and drive home avoiding boost.
    99.9% of ZL1 owners have this same BAP and have zero issues, rarely do they blow fuses when wired up properly.
    The only purpose of the BAP is to supply more voltage when the ECU demands higher pressure and the ECU cannot get enough voltage to itself.
    sounds like a better idea for safety then, originally thats why i wanted a big single pump setup so if it fails it dosnt work at all so easy diagnosis and fix
    This is how I soldered the wires to the fuse socket
    This is where I mounted the BAP
    And this is where the fuse socket plugs into the FPCM, right hand side is 12v power source for the BAP, left had side feeds 17v into the FPCM when boost pressure hits 5psi.
    Mar 2018
    Thanks for the tips Kirk.
    Where do you guys run the wiring into the engine bay? And where is there a boost port on LSA HSV's?
    Quote Originally Posted by Benno25 View Post
    Run the wire into the car, under the back seat, over to the drivers side, along the drivers side door under the sill plate, up behind the throttle there is a rubber bung, this bung accesses under the wiper motors, then T-piece into your boost port which is on the front left of the blower casing.
    Mar 2018
    Sorry for the dumb question, but does anyone have some pictures of where/how they've tee'd into the boost port?
    Benno
