Page 1 of 59 1231151 ... Last >>
Results 1 to 10 of 583
Thread: Lsx ve senator
    Lsx ve senator
    Been told by a few i need a new thread so here goes
    Started with a stock E1 VE Senator auto and mods thus far are
    RACE PREPARED ENGINE..........
    LSX Block 454ci
    callies 4.125 crank
    callies 6.125 rods
    4.185 wiseco piston
    BTR cam 239/254/ .632" .595" 114lsa +3 actual is 241/256@50
    Morel link bar lifters
    comp cams twin chain timing set
    LSX LS7 heads CNC'd
    melling high pressure high volume oil pump
    Evans water pump
    VMAX ported throttle body
    MSD Airforce intake manifold with nitrous express ported nitrous sytem
    Fast 65lb injectors
    Du Speed OTR CAI
    autotecnica catch can
    ATI Harmonic balancer
    External engine oil cooler
    standard starter and alternator
    ARP bolts thruout
    Aussie desert coolers radiator
    Hurrican 1 7/8 extractors, 3 inch mild steel xforce cat back, no cats, Varex mufflers, mickyinc made tips
    GEARBOX....
    t56 6 speed manual
    mantic twin plate clutch
    short shifter
    FUEL SYSTEM.......
    Fore innovation in tank triple pump system twin walbro 185lph fuel pumps, walbro 465lph fuel pump
    micro filter , controller, gauge, regulator
    Nitrous express direct ported nitrous system 150shot
    SUSPENSION.........
    whiteline front and rear sway bars
    various Whiteline bushes
    Walkinshaw lowering springs
    MRC shocks
    Full ground effects underbody with front and rear diffusers
    underbody rubber backed foil sound insulation to trans tunnel and fire wall, remainder underbody painted soundproofing
    Standard rims with toyo rubber front, Nitto's rear
    EBC yellow brake pads
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    http://media4000.dropshots.com/photo...209/031149.mp4
    http://media3001.dropshots.com/photo...913/124000.mp4
    SOUND SYSTEM
    Standard head unit
    2000watt amp
    twin kickers in boot
    FUTURE MODS.....
    drive shaft , diff , axles, Bilstein coil overs, BMR ch***is brace, whiteline adjustable lower arms and front lower arms rear,
    whiteline adjustable arms front
    Complete re-spray same color
    Koya rims with 255 rubber front and 305 rubber rear
    Re upholster interior same color, drivers seat molded to suit, sony head unit , xbox, playstation , pc, 2 more screens
    [IMG][/IMG][IMG]
    [/IMG]
    http://media3002.dropshots.com/photo...910/211835.mp4
    [IMG][/IMG]
    love the underbody aero kit, is the new engine in now?
    Not yet Gen-F... hoping this week... Im trying to see what cams are available with higher lift,, any suggestions?
    pir4te Guest
    Lsx ve senator
    Wow, very trick specs. Ditto the aero kit.
    This is what I had in my LSX454
    248/256 .652"/.652" 114+3 (with 1.8 rockers)
    https://www.texas-speed.com/p-1216-t...-camshaft.aspx
    You like saving fuel pir4te.. aero kit save a little UNDER 2LPH...
    Gen-F Not much split in that cam ... if you did an N/A lsx again woud u use that same cam?
    Jun 2011
    The Best Place in Oz
    Wow nice work on the aero kit, never seen one before
    Yes I would use the same cam it was well proven before I got it and I made 620rwhp out of it with a fast102.
    The good bit is it actually works...In Theory the car has negative lift.... Seat of the pants definitely sucks the car to the ground..
    Produces no drag, saves fuel..
    Gen-F ill save the dollars for the other engine, the LSX block and parts have already set me back ova 6k, will be ova 10k when finished... Ive spent over $23,000 rebuilding engines, $6000 on so called tuners who cost me one of the rebuilds then has the gall to say " i shouldnt have touched it because i didnt put it in" , so thats how to justify giving your car back with blown head gaskets and saying alls good, well done VCM... The leaking sleeves which really made my mind up ill thank Blackwell engines for totally stuffing up the original engine build.... Absolute pricks , there No excuses
    I asked my engine builder to put my flywheel on a diet. 3.7kg lighter.
    My old block is hopping on a plane to the U.S, going to ERL to see if they can save it. Fingers crossed
