Page 58 of 60 First << ... 8485657585960 Last >>
Results 571 to 580 of 599
  1. #571
    Bit of an update: waiting for the rotating ***embly and block to get back from machinist. he is waiting on a tool so he can measure the windows in piston accurately, dont ask me what that means. i think because he does block work in a cnc it has something to do with it.
    It should have been back ages ago but piston ordered were wrong so had to get another set.
    The bores had a ring groove at TDC which had to be honed out, there was also signs of fuel washing the bores. i wont mention who the tuner was.
    The rotating ***embly has been balanced with flywheel, clutch and harmonic balancer attached.
    Once the parts are back ,hopefully by wednesday, it will take a few weeks to get together. Builder said it takes him about 20hrs to build the engine, but have to allow a week waiting on the cam ,once its specced.
    These new heads should work really well, small port ,high velocity
    Lift Intake Exhaust
    .200 160 123
    .300 232 181
    .400 300 226
    .500 351 247
    .600 387 260
    .650 396 265
    .700 404 268
    .750 410 271
  2. #572
    Just ran out of time to have engine finished before Xmas . I did have to buy another car because I gave my daughter the 2014 VW polo I use as a run about. Grabbed the new VW polo, basically 50mm bigger rite around, smaller 1.0L 3 cyl engine with 12kw more power, 6 speed instead of 5. Cranked out 2500km so far and a great little car, the 6 speed gearbox is a cracker, avg 4.9L/100 so far. It's only about 430wkw down on wht the senator will have , fun anyway
  3. #573
    When is it back on the road? Curious how much is a block for your car?
  4. #574
    Hi Craze, will be bout 6 weeks I think. I paid $4600 for the block,
  5. #575
    Ive sent my extractors and catback to axle off to get ceramic coated. Will be able to run fully flat underbody all the time with it ceramic coated.
    [IMG][/IMG]
    Im also trying to sneak past the mrs a set of race seats that ill have upholstered in original colors. Touch n go on that one but im hopeful i can baffle her with bullshit. Shes gettin wise to me tho lol
  6. #576
    Recieved a call from ceramic coater today saying extractors and exhaust to diff is ready.. $1100 all up, that will keep the heat down
  7. #577
    Newcastle, NSW
    Will you run the exhaust under the aero? Like, exhaust will still be visible or will it be
    enclosed within the aero?
    GTSR HERON WHITE MANUAL build # 0068
    VK HDT Calais Director Build # 2107
    2010 VE SSV SPECIAL EDITION
    2018 FORD FOCUS RS LE
  8. #578
    Hi Theo , the exhaust will be enclosed so underside of car will look like my model pic a few posts earlier. Down the track I will modify again. I'll relocate fuel tank to spare wheel well, think it will be about 110L tank , by relocating tank I can then run exhaust differently Which in turn allows me to modify rear bar for a more aggressive/performing rear diffuser.
    With tank relocation and full tank of fuel should be very very close to 50/50 front to rear.
    All will have to wait until next yr tho due to house build. When I do start the 1st port of call will be carbon fibre fabrication, boot,bonnet, front guards, rear doors, underbody aero, tank n exhaust mods next then paint, interior is partly underway, I have race seats being upholstered now ,leather same colour as original ....hopefully early 2021 finish
  9. #579
    Is this going to be street driven?
  10. #580
    Quote Originally Posted by craze View Post
    Sure will be craze, will drive it weekends and few times a week. Getting off the line it can be hard but 90% the time successfully
    Drivers seat getting done is comfy , it's had extra padding put in to suit me, plenty in the arse for longer trips, p***enger seat is larger with padding to suit upholster guy (he taller n heavier than I) both seats very comfortable wrapped in a top quality leather. I hvnt weighed to compare.
    I'd expect 30kg or more
