Page 17 of 18 First << ... 715161718 Last >>
Results 161 to 170 of 178
  1. #161
    No the OEM charger gasket stays in place on the blower but since you've gone to the effort to basically take the blower off the engine to do the isolator it's not a bad time to also fit a set of blower spacer plates.
    Lol good sales pitch there
  2. #162
    Quote Originally Posted by Eors View Post
    Lol
    Was only thinking its nearly completely off of if there is a time to do it, then it's when you do the isolator
  3. #163
    Feb 2015
    Blue Mountains
    There is another option and that is to get a top pulley upgrade and request a solid coupler be put in.
    For those that donít which to do yourself.
    Pretty sure the top pulley on own (2.55Ē) is about max can go boost wise without injectors etc.
    Kirk you forgot about lid spacers!!!
    And nearly loosen supercharger bolts so you can lift charger to fit screwdriver handle under it, that will give you enough room to remove.
    Took me 3hrs including changing fuel injectors out, taking pics, having a drink and not rushing.
    Hyundai Accent 1.6 manual (current PB 590kms til fuel redlight!!!)
    GenF2 30yr Senator (stock cam/heads 10.63@131.99)
    Previous GenF my15 Gts (was fastest stock cam/heads 10.68 @ 130.3)
    Previous VXR8 (vxr
    Previous GTS-r (uk)
  4. #164
    Quote Originally Posted by NickGts View Post
    For those that don’t which to do yourself.
    Pretty sure the top pulley on own (2.55”) is about max can go boost wise without injectors etc.
    Which isolator did you end up using?
  5. #165
    Feb 2015
    Blue Mountains
    I got mine from LPE - lingenfelter, I believe they are same as Eaton ones and think same as ones Yella Terra use
    Previous VXR8 (vxr
    Previous GTS-r (uk)
  6. #166
    Does anyone know with certainty that the GTSR's have the spring loaded isolator?
  7. #167
    All 2017 LSA models and some late 2016 models have the spring loaded isolator.
    Confirmed on a GTSR sedan, GTSR Maloo and Nicks 30th Anniversary Senator.
  8. #168
    Oh well...must order one and swap it out
  9. #169
    Aug 2017
    Has anyone other than Nick had any experience reporting 2017 cars with the noise and getting a replacement blower or isolator from HSV/Holden?
    Edit. So this is going to be interesting. Andrew at HSV says the blower is a Holden warranted part. In any case, I've had it looked at by Holden Techs who acknowledge that mine is noisy too.
  10. #170
    Aug 2017
    I'm getting my SC replaced under warranty.
    Does anyone know the part number of the SC with the spring loaded coupling and that of the SC with the solid coupling?
