Page 13 of 18 First << ... 31112131415 ... Last >>
Results 121 to 130 of 174
  1. #121
    Quote Originally Posted by ASD14 View Post
    So they have gone back to spring isolator instead of solid.. that's interesting.. is the "new" spring isolator different or improved from the old one?
    If it rattles then it's metal on metal and it's a problem....no idea why they would go back to the spring when the solution in the aftermarket has been a solid one and Eaton even changed to a solid one.
    My HSV was one of the first to come out with the solid Eaton isolator as I was prepared to change it out and on the 2nd day of owning the car and opening the snout on the charger I found I had a solid one from factory.
    Looking for colder IAT’s? we’ve achieved 11c IAT2 on a 41c day and -8c during winter.
  2. #122
    Feb 2017
    Hong Kong
    Sorry to be necro this post from the past, but was wondering what the latest on it is. Could we expect the solid part as per what you found on yours GenF-GTS?
  3. #123
    Quote Originally Posted by Air View Post
    I've heard rumours that the spring one is back in there now....no idea why this would be though...
    If this is true it's bad, in my opinion I would be asking HSV and me also being fussy I personally would be taking a look or next best option for those not willing to open it up call a few workshops and ask
  4. #124
    I can confirm that recently a friend with a 2017 model opened the blower up and found the spring loaded isolator.
    I have no idea why Eaton would go back to this especially after the mass recall and cost in the USA to recall all LSA blowers to be upgraded to the solid version which was an entire blower swap with the old blowers being sold off in masses on eBay for as little as $500.
    So yes if you have a 2017 LSA and it's rattle highly likely it needs a solid isolator
  5. #125
    Goldie
    Just doing some research on this as I believe my 2014 GTS with 112k km on it needs the spring loaded isolator replaced. Apparently the OEM solid isolater piece was always a temporary fix from GM as it makes a worse noise and doesn't absorb the initial kick of increased RPM from throttle but doesn't wear out the isolator like the spring loaded one.
    This is apparently why Eaton has made a revised spring loaded one with a different design and materials that 'should not' create the unnatural wear the original did.... whether or not thatis the case remains to be seen.
    My Rides:
    2014 Gen F HSV GTS Auto in Sting Red;
    2015 VW Golf R Mk7 DSG in Lapiz Blue.
  6. #126
    FNQLD
    My MY15 now has a very slight rattle i think its that part?
    HSVsaid its within spec at least i have it noted as the warranty ends in a few months.
    Might be time for an MY19. joke.
  7. #127
    Goldie
    What's your build number Gen F? I'm 846 delivered in February 2014.
    My Rides:
  8. #128
    Goldie
    I've got the GTS in with HSV today and presented them with the GM service bulletin 13313. We'll see how this plays out.
    My Rides:
  9. #129
    Quote Originally Posted by Snowdoggydogg View Post
    I'm #998 and my blower was replaced under warranty within the first few months due to a rattle in the blower. I assume it was this part that was causing the issue, so seeing your car is slightly ahead of mine I'd guess it has the old style part in it
  10. #130
    Feb 2017
    Just a quick question. As this is my first Hsv. Would a October 16 model club sport LSA have a solid isolater fitted or did they fit spring type for this model
    Sent from my E6653 using HSV Forum mobile app
